RS2 cooling hoses
  • Veg
    • Jul 2013
    • 124
    RS2 cooling hoses
    Basic question: do the S2 silicon coolant pipe kits from Roose fit an RS2? I am re- coring the 2nd rad and putting in a new thermostat so thought I'd change all the pipes (had too many classics where the pipes fail).
    Also whilst it's all apart is there anything else I should do?
  • jade
    • Jan 2005
    • 1811
    The set up on the rs2 is a little different, Mainly the Hose that go's the header tank it also branches to a metal pipe that go's to the heating, I have spoke to Paul about this and he will make one but needs a sample, mine is due for replacement as my hoses have start failing one by one but have not had a chance to remove mine, so I will be up for this hose also if you can supply a sample for Paul at roose
    Pm if you want more info
    Rgds
    RS 2 580HP
    • Veg
      • Jul 2013
      • 124
      Okey dokey after ADI I will strip it down and send my pipe to Roose and see what happens!
      • jade
        • Jan 2005
        • 1811
        Ok Cool, If you want I can email Paul as I have spoke to him before about it and maybe it is possible to do a small group buy, I would have though there were a few other people that might need the same hose
        RS 2 580HP
