RR Flywheel or 3B of a S2
  • Jaap
    • Oct 2003
    • 258
    Are there any diferences in flywheel form a RR engine to a 3b from a s2 coupe.
    I know that the centerhole is bigger, but the thiknes of the plattes???
    Greets Jaap
  • aelred
    • Jan 2005
    • 761
    The flywheel differs in respect that the RR has no spigot bearing in the flywheel as the input shaft on the RR sits via a spigot bearing in the crank.
    Aelred
    • Jaap
      • Oct 2003
      • 258
      3b-rr
      The rest is identical???
      Thanx
      Greets from Holland
      • aelred
        • Jan 2005
        • 761
        Thanx
        Greets from Holland
        Pretty much the same.
        rgds
        Aelred
        Aelred
