Over boost?
  • jamie9048
    • 253
    ive checked the temp at random points across the radiator and its all similar temps the only thing different is the aux rad is missing i`ve had it reconditioned just never got round to fitting it the car seems to get up to around 100 degrees and after a while the red water warning light starts flashing the cooling fan works fine...
    i`ll refit the rad before taking the head orf
    • Donnie
      • May 2010
      • 112
      The absence of the aux radiator should not be a problem - most s2's sooner or later end up without it and continue to run at normal temps - as long as the disconnected hoses are blanked off and NOT connected together (it has been done before).
