TDI Troubles
  • bikerjim
    • Feb 2008
    • 1028
    I believe you can use the snapon tool to do it, I borrowed one to check fault codes on mine and found an option for something to do with pump calibration on that. Let us know how it goes.
    • shaun5
      • 1610
      Well I put a snap on solus ultra on the car tonight and it doesn't communicate with the car (the bloody thing doesn't communicate with much, it always says the same when Im at work )
      Anyone got any more suggestions? Looks like im gunna have to pay someone to put it on VAG-COM to adjust the pump
      One other thing is if I hold the throttle pedal at steady revs, say 1200 rpm it will die on its own and if I gently press the throttle it doesn't respond straight away (I have to press it half way)
      • Monkeymagic
        • Mar 2012
        • 3419
        There must be members down yourr way with vcds....
        • Monkeymagic
          • Mar 2012
          • 3419
          The way i see it you need to. Plot the timing cloud on the graph. If it plots okay i would suspect an electrical issue with the pump.
