cylinder head renewal parts list
  • vonbeck
    • 2455
    As the above i will probably be having this done early next year, i`ve got a list (see below) of things i think i need can anybody suggest anything else why its being done and best places to locate said parts this is an old list off dougs thread so part numbers could have changed its for an ABY
    cheers guys
    Cam Belt 054 109 119
    Cam belt idler 078 109 244 F
    Cam belt tensioner 054 109 242
    Water Pump 054 121 004 A
    Thermostat 069 121 113 Â
    Thermostat Seal N 901 368 02
    All three drive belts.
    Belt V 034 260 849 12.5 x 912
    Belt V 034 260 849 E 12.5 x 1030
    Belt ribbed 034 903 137 B
    Crank bolt 034 105 229 A
    Turbo to EM bolts
    Turbo to EM gasket
    2 wastegate bypass pipe gaskets.
    RS2 Head Gasket 034 103 383 AD
    Head Bolts 034 103 38J C
  • andy10v
    • 5996
    Crank belt timing pulley, either a new audi one, about £35 iirc, or a billet steel one for £90, that should last forever.
    Billet pulley from terrybullwon
    EFI express do them, tommisbillet, volcano rs?
    The stock pulleys are known to break with catastrophic results.
    Alex did a victor reinz part no list
    Might want to check what all comes in a head gasket set
    Originally posted by Error404
    20v Head gasket set - 02-29335-01
    Sold ABY-stock
    • andy10v
      • 5996
      Other random thoughts;
      Valve stem seals
      check valve guides for wear
      There is a plastic coolant flange on the back of the engine that is liable to break if you pull the hose off it, might be worth having a spare to hand in case you disturb it. You can get a new plastic audi one, a steel one from a 7A (could be corroded), or Rusty does an aluminium replacement one.
      Are you taking the manifolds off the head?
      If so, exhaust manifold studs/nuts as required. Also an easy time to change the injector seats (can cause boost leaks)
      Probably also an easy time to replace all the vacuum hoses.
      Clean your PCV system.
      Sold ABY-stock
      • pasbogdan
        • Sep 2009
        • 1160
        • Country: Romania
        Head gasket kit:water rail gaskets,cam cover gaskets,im and em gaskets,valve seals,head gasket,tb gasket(no need to change,you do'nt remove tb),colant sensors shims.No need to buy rs2 head gasket.Any decent(victor reintz,ajusa)head gasket kit will have a metal head gasket.Agree with andy10v about rear colant plastic flange,and very important crank sproket.Also the injector seats...Andy,you realy work on theese engines or you read the forum alot?
        • andy10v
          • 5996
          No, just fun/hobby/fix my car. My dad has been doing it for a while though, he had a crank pulley fail on his 100s4 in the 90s.
          Sold ABY-stock
            The Reinz 20v complete head gasket set contains most of what you need gasket wise.
            MLS headgasket
            Inlet manifold gasket
            Exhaust manifold gasket
            Throttle body gasket
            Water rail seals
            Cam lip seal
            Cam cover seal
            VSOS
            You can get some nice wastegate flexi gaskets off Rusty.
            • Christophski
              • 3632
              And dont forget to get yourself some nice new exhaust manifold studs and copper nuts... and some nice new water manifold bolts... and some nice new nuts and bolts for the turbo and wastegate and flexi.... and the rocker cover allen key ones....
              Got lots of those bits from All Parts but make sure you take an old one of each item with you to match up to....
              • vonbeck
                • 2455
                cheers guys where`s best place to get gasket set?
                • europeanme
                  • Oct 2005
                  • 3817
                  injector seats for defo.....
                  Quattro corner might have a set.....I say might.....
                  • Christophski
                    • 3632
                    I got a Victor Reinz one from my local GSF...
                    • AndyP
                      • 6049
                      http://www.gsfcarparts.com/114vg0440
                      And as Mike said, injector seats, about £4ea from dealer.
                      • vonbeck
                        • 2455
                        cheers guys I'm on it. part numbers for injector seats? as my audi dealer has trouble finding my car on their system let alone the feckin part
                        Hi Andy went to have exhaust done on monday got a phone call in the afternoon blokes welders packed in have to wait till 14th nov now
                        cheers for the linky
                        • AndyP
                          • 6049
                          Shame about the exhaust
                          • audinut
                            • Jul 2009
                            • 2195
                            can do the gasket set cheaper :-)
                            NOT a car dealer! just an S2/RS2 enthusiast
                            • vonbeck
                              • 2455
                              pm sent
