Can someone lend me a boost testing kit?
  • LitD
    • Nov 2011
    • 38
    Hi all,
    Can someone in the UK lend me a boost testing kit please? All my boost has wandered off.
    Thanks
  • shaun5
    • 1610
    Where in the UK are you? Im sure there will be someone close to you that can help out
    • Monkeymagic
      • Mar 2012
      • 3419
      I have a genuine one at my unit. I wont lend it out but IF you are local you csn use it.
      • LitD
        • Nov 2011
        • 38
        I'm based on Cardiff and it's for an AAN while I think about it
        • Monkeymagic
          • Mar 2012
          • 3419
          It wont matter which engine its for it has a staggered fitting to fit vsrious inlets.
          You pressurise to 1.5 bar with engine off. Combined with some soapy water if needed it will show any leaks.
          • LitD
            • Nov 2011
            • 38
            Only mentioned it cause I know some are staggered and some are single size and I'm not sure if all the pipework is the same across the different engines.
