valve springs??
  • zlobo
    • 967
    valve springs??
    i an going to boost a bit more this year so i decided to replace the valve sprins an i am wondering wich onces i am going to use???
    any ideas any one??
    i am goint to lift 11mm
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
  • zlobo
    • 967
    does every boddy use original valve springs????
    kostic.nu
    • Graham
      • 1622
      I am sure a while ago someone mentioned that titanium ones are the best for out and out performance.
      • zlobo
        • 967
        ok
        kostic.nu
        • ThatGUY
          • Sep 2004
          • 794
          I too am thinking about building my head... If I upgrade springs shouldn't other things be upgraded as well? And would there be accelerated wear on parts? Is there any real reason if I don't plan on raising the rev-limiter?
          //-\\ ((_)) //)) //
          • zlobo
            • 967
            i have upgraded just the cams to shrick cams and now i am thinking of puting in springs from kent cams. I am not shure yet if i am goingr to rise the rewlimit to 8000rpm.
            kostic.nu
            • Albert
              • 1500
              • Country: Poland
              I'm going to have my delivered from Cat Cams in Belgum. http://www.catcams.be/
              AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
              • zlobo
                • 967
                are you going to use the hydralic lifters?
                kostic.nu
                • Albert
                  • 1500
                  • Country: Poland
                  Yes, but not form catcams, only springs + retainters form them
                  • zlobo
                    • 967
                    ok,
                    did you order the upper retainer 99370 or 99380 ?
                    and springs 902-5009 (double) or 99859 (double) ?
                    you know that if you use the retainers from cat cams you have to remove the valve seal
                    kostic.nu
                    • Tommy200rs
                      • 285
                      7A high lift cams with original springs start to rattle ~ 7600-7700 and gives a nasty feeling during drive. Crane 4 cyl 16V Golf springs are said to be good up to 8000. Find the Crane catalog & VW
                      • Albert
                        • 1500
                        • Country: Poland
                        zlobo You have a PM
                        • Ski
                          • 2591
                          No i use QR sport's own spring. Made more difference then a 280 chip.
                          I belive it puts more strain on the turbo (good excuse to upgrade that when it blows).
                          ABY Coupe
                          • auditude
                            • 407
                            Are we still talking about valve springs? The strain on the turbo comment makes me think we're now discussing wastegate springs. If that comment was regarding valve springs, how is the turbo affected by changing them?
                            Kenneth
                            1990 Coupe quattro
                            1991 200q20v x 2
                            1985 4ksq 20vt project
                            1986 Coupe GT 10vt project
                            2006 Honda Ridgeline
                            1998 Honda VFR800FI
                            • caterpillar
                              • 2480
                              why does'nt they have a english website i doesn't understand a f**** s***
