Proper torque settings for 12.9 grade main bolts?
  • Thuppu
    • 4115
    So, the stock main bolts(10.9 grade) torque specs are 48ft/lbs. ARP mains 65ft/lbs, but this can bend the main caps and press the clearance to zero.
    So I suppose 12.9 grade bolts should be something between these? What would be the ideal sweetspot?
  • Laaf
    • Oct 2010
    • 275
    I torqued my main ARP studs to 81 Nm / 60 ft/lbs as this instruction; http://arpinstructions.com/instructions/204-5404.pdf
    No problems with clearances what so ever and the crankshaft spun easy so I didn't bother with line honing. I found this cheap unused on the swedish Audi forum so that's the only reason I bought them, otherwise I would just have used the OEM ones.
      I found the ARPs squashed the caps by only approx 0.01mm so leaves plenty of clearance
      • Thuppu
        • 4115
        Ok, great to hear guys. I guess ARP's are stronger than 12.9 grade bolts, so what would you use for torque, 55ft/lbs?
        • AndyP
          • 6049
          You rebuilding your engine again??
          • Thuppu
            • 4115
            No, not yet. This is an other engine I can throw in and drive the winter. Have to take apart the "main" engine an try to figure out why it's eating oil.
            • prj
              • Mar 2010
              • 6308
              Eating is the correct word indeed. I think it was about 1:5 ratio of oil to fuel consumption last time
              • Laaf
                • Oct 2010
                • 275
                Had a look around on Nordicaudi and it was mentioned 65-70 Nm for 12.9 bolts used with a girdle. Guess he used a kit from CP-Service where most of the swedes source their 2.2t tuning parts
                • pasbogdan
                  • Sep 2009
                  • 1160
                  • Country: Romania
                  Try them,torque and use a internal gauge.First measure with them half torque or less to get sure that they are perfect round.They usualy are not
                  • driftin jo
                    • Sep 2007
                    • 2222
                    Whatever bolts you use they need to be torqued to achieve the correct amount of pre load. This is done by measuring how much they stretch. Im talking about elastic stretch here not plastic deformation that you have with a 'stretch bolt'.
                    The main bolts need correct pre load as they are subjected to cyclic loading. If there is insufficient pre load then work hardening and eventual failure can happen. I would PM jp as he will be able to tell you how much stretch is right.
                    • AndyP
                      • 6049
                      No, not yet. This is an other engine I can throw in a drive the winter. Have to take apart the "main" engine an try to figure out why it's eating oil.
                      Me too, see here
                      How much is yours using and what do you think is the cause??
                      PM me or reply on my thread if you don't want to clutter this one!
                      • V6quattro
                        • Sep 2008
                        • 949
                        I also torqued my ARP mainstuds to 81Nm and the crank didn't spin at all! So i have line honed mine. Strange
                        1360kg/600Whp Avant 0-200km/h 9sec
                        • Thuppu
                          • 4115
                          Originally posted by AndyP
                          Me too, see here
                          My uses !!!SHITLOADS!!! and it's coming past the rings. Can't think of nothing more than wrong(too big) piston to wall clearance combined with low tension oil rings.
                          • Dybro
                            • May 2008
                            • 69
                            • Country: Denmark
                            If you can read German THIS might be interesting for you. It has torque specs for different friction coefficients - READ different alloys and coatings; dry, oiled or with moly paste.
                            1993 AAN UrS4 Sedan
                            • pasbogdan
                              • Sep 2009
                              • 1160
                              • Country: Romania
                              If all the rest is ok(valve seals,turbo,rings in piston grooves tolerances etc),honing grit to deep keeping and burning lot of oil,or grit to fine not keeping oil and destroying rings?
