So just curious of y'all opinions... I see lots of really clean engine bays and people running no timing belt cover... what are the thoughts on this?
I see:
Pros - easier to check condition of belt, one less piece to remove, clean mechanical look if you get a nice pulley
Cons - chance of rock causing damage/getting wedged in (unrealistic?), less protection from the elements
Would you run with or without cover? Thanks
I see:
