What do you guys think about this?
I want to clean up my engine bay and eliminate components that could leak boost, cause crankcase pressure problems, interfere with Air/fuel ratio on VEMS or just aren't necessary for the engine functioning.
What would happen block off all emissions connections to the manifold, delete the N80 system but still vent the gas fumes, and just use the turbo inlet pipe to pull crankcase ventilation? Please excuse my Paint artwork.
Like this: (RED X ARE FOR DELETE/BLOCK)
At that point the only downside I see is maybe extra crankcase pressure with the throttle blade closed.
0-200km/h 9sec
