It sounds like the camshaft chain to me... noise comes when getting the foot out of gas pedal and letting engine revs go down by itself with engaged gear (3 or 4th). And it's irregular - compared to engine speed...
Do You think that's really the chain? I'm little worried, 'coz service days are checked on february... Can it be dangerous to my engine? What else could make such a noise?
Any ideas are welcome
OOOO
! I had a simmilar noise in my NA 20v & it turned out to be a broken inner exhaust valve spring. I only found out after the engine had spun a rod bearing
due to lack of oil. The broken valve spring ate the top of the guide & the oil was sucked out of the engine. I was pulling about a ton (going about a 100 mph) and the cats burned up all the oil, so no tell-tale smoke. The "low oil"warning came on too late.
I work on automobiles as a profession. If it can happen to me it can happen to you.
