rs2 coolant manifold rubber seals
  • Eastcoastrs2
    • Sep 2013
    • 95
    • Country: Australia
    I had a coolant leaking off the bottom of the engine and after some investigating found the rubber seals for the manifold where the coolant enters the engine where shot.
    There is three pink and yellow o-rings and one black seal.
    I am trying to find part numbers and /or where i can buy the three o-rings and the other rubber seal.
  • caterpillar
    • 2480
    not shure what part you want...
    • Eastcoastrs2
      • Sep 2013
      • 95
      Looking in the engine bay from the front. About halfway down the exhaust manifold on the right hand side of the engine block there is a metal piece which is 4 pipes that flow coolant into/out of the engine block.
      If you follow the oil dipstick down and look across to the engine block you will see the 4 metal pipes i mean joining the block.
      I need the rubber o-rings/rubbers that seal this piece to the block.
      • Eastcoastrs2
        • Sep 2013
        • 95
        Sorry i meant intake manifold, the one with porsche on it.
        The parts i need are the seals for the water manifold similar to this o34 motor sport one.
        • caterpillar
          • 2480
          the orings 3 pc... N 028 203 4 the triangel gasged; 027 121 139A..
          • Eastcoastrs2
            • Sep 2013
            • 95
            Thanks very much caterpillar!
            Now i can look forward to getting her back on the road
              C4 AAN Coolant hose PNs (some = ABY and ADU)
              Originally posted by Eastcoastrs2
              I had a coolant leaking off the bottom of the engine and after some investigating found the rubber seals for the manifold where the coolant enters the engine where shot. There is three pink and yellow o-rings and one black seal. I am trying to find part numbers and /or where i can buy the three o-rings and the other rubber seal.
              Just to confirm what others have said Items 41 and 42)
