Really depends what you want to do with the engine. Is it drag? Track? Everyday? Use...
Cause if it's the latter of the 3 then no need to spend that extra money on rods. But if you are building a high end engine with specific requirements then it's worth the hassle on looking at the small print details.
I use the car for track days, also like to drage a few times. But i also use the car for fun on the streets to race lambo's porsche's
It's a stroker with high lift cams cnc ported head. So i can say its not a normal engine im building.
And the carrillo are just 200dollars more so that is not a problem.
I see. Yes in that respect it's worth the hassle then.
Carillos are only 200$ more than Pauter but both are much more than a simple set of scat rods. That's why I mentioned prices.
