Anybody who knows which rods are strongest pauter x-beam or H-beams carillo or Manley or ?
Pauter or
dont think you will sence the differce....; you/ the people at this forum need more info what engine specs; and how to use the engine... the dayli driver or drag engine..?? -
they are all better than the org audi's...its about the rod and strok ratio too.. and type of engine...2,2 or 2,6Comment
China rods are proven to hold quite a lot of power, so it really doesn't matter wich rods you use.
The left more narrow rod is from a engine tha made 800+hp with stock pistons. No problems for the rods. Later a piston did go in half though. If I remember right the rods was sold as SCAT's. The rod on right is Aronmatic's rod, a lot more fatter.
But then again, Pauters do look sexy.
BMW 740iA e38 - ProjectComment
If only 700hp use cheaper H-beam, if go more near the 1000 use X-profile . As x -beam profile is different dimension and have more material.Last edited by FCP-ENGINEERING; 6 December 2013, 07:33.Audi S4 2.6 20V STROKER kkk26/27Comment
Mine 2.6 was not the best idea to built as done in short block 144mm rods TDi crank 95.5mm stroke and lowered custom FCP pistons 82.50mm.
Such engine is okey for 500-600hp town daily car, cant run more when 7200rpm as big risk to destroy engine. But runs like a diesel NM in low rpm, and fun begins on 2500rpm.
My recomendation, to use x-beam rifle drilled rods, woessner pistons CR 8:1 up to 82mm bore size in diesel block with 95.5mm storke CR will be 8.7-9:1 (fits stock MLS gasket 30-40eur, other way 83mm gasket cost minum 200eur). Engine size 2,5+liter.Audi S4 2.6 20V STROKER kkk26/27Comment
Definitely interesting build, how often do you reach 7200rpm & how many miles has this engine run?Dez
Never did overtime until i purchased........s2
