Antilag System with motronic
  • Billman
    • 4129
    Hallo, i was wondering, is an antilag system with the stock motronic system possible?
    Maybe with an extra module or something like it?
    Greetings
    Go Holset or Go RS4
  • WabTheKing
    • May 2004
    • 2567
    Greetings
    hi,
    try these guys but dont think you can do it on a standard ecu
    http://www.034efi.com/
    • Mihnea
      • 1288
      Why would you need anti-lag to start with? IMHO for street use it's not that great, you get higher fuel consumption and you do compromise reliability. I have never looked into doing specific antilag with Motronic but I'm sure it can be done. Flame throwing on lift-off is feasible with no problems, so I guess anti-lag can also be done
      It just takes lots of time....
      IMHO, if you need anti-lag with a turbo that gives full boost around 4k RPM, you have a problem with changing gears improperly. The solution is a big block V8 and an automatic transmission in this case
      Mihnea
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • Billman
        • 4129
        I thought it will be good when you can choose it with a button or something like this! Maybe if having 2 programms in the motronic and changing between them!
        One for road racing and one for rallying! ;-)
        Go Holset or Go RS4
        • Mihnea
          • 1288
          rallying with an RS2????
          2 programs in the ECU is possible, I've been doing this for quite a while now...
          mihnea
          www.MRCTuning.com
          info@MRCTuning.com
          Workshop Directions
          • NoNonsense
            Forum Sponsor
            • Apr 2004
            • 673
            Originally posted by WabTheKing
            hi,
            034efi is purely standalone. Well, they offer a supplimentary ECU for extra fueling (incase you add more injectors). To get the anti-lag option, though, that's only available on their full standalone system.
            Joe "NoNonsense"
            axis motorsport
            joe@axismotorsport.com
            • Billman
              • 4129
              I Preffer the motronic!
              Rallying (or try to do it) with an Rs2 is quite fun!
              Go Holset or Go RS4
