More questions about RS2 Spec
    Fuel Pressure Regulator Info
    Originally posted by Error404
    IIRC RS2 FPR is 3.8 Still as above not necessary, send it to PRJ I am sure he has a tune perfect for you
    Agree and agree.
    More 20VT fuel pressure regulator info here:
    Which was accessed via clicking on the appropriate label in this live Engine Bay Device Map:
      I fitted a 3.8 to work with rs2 chip set, as it was a smidge rich at WOT. Of course, cams are different too, so depends how ocd you want yo get with it...
        Intake cam is the same (AAN, ABY and ADU). ADU exhaust cam is different.
        ADU Exhaust cam sprocket with G40 Cam Sensor shutter is different if you are *REALLY* ocd.
        AAN/ABY "105" exhaust cam sprocket and shutter wheel:
        ADU "105B" exhaust cam sprocket and shutter wheel:
        And then there is the cam timing:
          Aye, my mistake. Just got back from a 3 hour drive in the S2 in terrible weather
          • rynaqui
            • Mar 2012
            • 2752
            • Country: Malta
            #20
            So here is the list of parts I have set to purchase:
            Oil cooler
            Exhaust manifold gasket
            Studs
            Rocker Cover Gasket
            Turbo Oil Feed Gaskets/Bolts
            Diff Hanger Bush
            Any more recommendations?
            1996 S2 ABY Silver
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #21
              Oil cooler? Is yours defective?
              • rynaqui
                • Mar 2012
                • 2752
                • Country: Malta
                #22
                It looks a bit..on the ugly side
                While I'm in the process of making a new turbo I guess it's not a bad idea to get a new oil cooler and clean out the oil lines as well
                1996 S2 ABY Silver
                • K Simmonds
                  • Dec 2007
                  • 7627
                  As your going RS2 spec and your in a pretty hot country I think I'd go for at least a 13 row aftermarket cooler located in the OE position. I take it you still have the Aux rad?
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
                  • rynaqui
                    • Mar 2012
                    • 2752
                    • Country: Malta
                    #24
                    Yes I still have the aux rad, hmm a 13 row oil cooler in stock position?
                    1996 S2 ABY Silver
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      A few folks on here have fitted larger oil coolers in the OE location, see if you can find a thread with a good example so you can see whats involved. If the Aux rad is done away with then that makes a better location but I'd want to keep that where you are.
                      My 13 row setup cost me about £130 using fancy AN fittings and braided pipe, can be done for a lot less if you not so fussed about appearance. Cheaper than a brand new OE cooler and pipes and way more efficient.
                      1994 MTM RS2.
                      2000 B5 TQS.
                      • rynaqui
                        • Mar 2012
                        • 2752
                        • Country: Malta
                        #26
                        I have another question
                        Is the Forge 007 DV I have ok for an RS2 setup? Thanks
                        1996 S2 ABY Silver
