Intake Pressure Test
  • quattroboy
    • 164
    • Home: United Kingdom
    Just done a Pressure Test with Lee's Kit on my AAN.
    Blocked the Camcover Breather Pipe and put 10-15psi into the MAF Adapter.
    No leaks present, or at least I don't think so anyway but I did hear air "escaping" through what appeared to be the Wastegate?
    The Pipe running from the WGFV to the Banjo Bolt Union just under the Wastegate Top Cover was letting Air through. When I crimped this pipe the "escaping air" noise stopped, then started again when I released the pipe.
    I have tested the Diaphram with the MityVac and it holds 20hg Vacuum.
    The car pulls like a train with no problems apart from the turbo which seems to spool up with a longish whistle............probably because of the slush box maybe?
    Whats all that about or is this "escaping air" noise normal?
    Your thoughts are appreciated
    Ta
    Dave
    1997 S6 Avant
  • audiman
    • 4827
    You shouldnt get any air escaping AFAIK
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • dkw_dude
      • 555
      • Country: Norway
      I have the same experience when pressure testing. And a hissing sound when turbo spools. The price of a new wastegate is insane (here in Norway equivalent to ~1000£+ ) so I'll put that on hold for a while.
      Got hold of a used WG, but it was in no better condition. Have given it to a mate who works in a machine shop, he would take a look at it for me (try to make a new bushing for the valve). He's having trouble finding out exactly what material is used in the bushing though.
      I'm also interrested in opinions on the subject.
      Leif-Helge
      -91 S2 VEMS and Comp Turbo
      -12 B** 530XD Touring "S2 parts transporter, and daily driver"
      • martinjs
        • 3205
        It air passsing through the seals of the turbo isnt it, mine does this, think paul n's does too.
        • Dr H
          • 1175
          Mine makes a massive hissing sound when the turbo spools (as Paul N he's heard it!) but is only down about 0.1 bar on boost. Static pressure test reveals no leaks.
          I've come to the conclusion that it's the EM, I reckon it's cracked. At cold start I sound like I have a slight 'blowing' noise and if you lift the bonnet you can smell exhaust fumes. Once things are warmed up it's fine but when you make it boost it sounds like it's loosing air.
          Ex 1994 Avant - now driving a Lotus 340r
            Ta
            Dave
            What I think you are describing is normal. During a pressure test you should really blank off the control hose going to the WG. Reason being that pressurised air gets thru the WGFV in its position with the ignition off.
            What has always weirded me it is that the control chamber of the WG is NOT supposed to be completely air tight - during such a pressure test, air always bleeds past the valve in the WG. I've proved this on several WG's just by connecting an air line to the control port and you can't sustain any sort of air pressure in the chamber. Mihnea has always assured me this is OK and normal.
            Alternatively, the noise you might be hearing is pressurised air sneaking past the seals on the turbo input. Don't forget when you do this test thru the MAF hose that you are presenting air pressure at a hose which normally sees vacuum ALL the time. The turbo SUCKS air in thru the MAF hose remember and blows it out the output hose. That seal is not designed to withstand boost pressure. Mine leaks air there - you can hear it bubbling into the central housing actually.
            Paul
            • quattroboy
              • 164
              Sounds like I have nothing to worry about then!?
              You just gotta love this forum
              Thanks for the replies guys. I will be testing another AAN very soon so it will be interesting to "listen" to those results.
              Paul, I will blank that Wastegate Hose and have another fiddle about.
              Will post my findings on the other AAN when test completed.
              Ta very much
              Dave
              1997 S6 Avant
              • Billman
                • 4129
                Where can i get this lee's kit! Any other topic with it? I htink i must do also a pressure test! Just to be sure!
                Greetings
                Go Holset or Go RS4
                • horvathg
                  • Dec 2003
                  • 556
                  Try to visualize your leak with cigarette or rather cigar smoke pumped into the system instead of air. It should make a hissing leak visible if you are lucky. Make your pump suck on the cigarette somehow . Makes no harm.
                  Gabor
                  96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
                  • quattroboy
                    • 164
                    Greetings
                    1997 S6 Avant
