Lumpy engine
  • Jack4688
    • May 2010
    • 1004
    Lumpy engine
    On the drive to work this morning I got a couple of flat spots and it eventually turned into lumpy engine running. By the time I got to work it was very lumpy indeed but seems to disappear after about 3,000rpm.
    Does anybody have any ideas what could be causing it? I'm hoping it's not something too expensive right before Christmas
    Thanks
  • K Simmonds
    • Dec 2007
    • 7627
    What state are your plugs, coils and low tension wiring in?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • Jack4688
      • May 2010
      • 1004
      I couldn't tell, I spent 5 minutes pretending to know what I was looking for at lunch then gave up
      Thanks for the pointers though, I had people suggesting the same on my thread here
      • Thecrispynoodle
        • Jul 2012
        • 269
        Don't rule out battery dieing on you, especially at this time of year. I have had identical symptoms with other cars engine wouldn't run right for a few weeks before it manifested itself as an obvious starting issue.
        • Jack4688
          • May 2010
          • 1004
          I'll bear that in mind thanks It's in for a comprehensive service at the moment. If this issue comes back I'll consider the battery
          • Cymru1
            • Sep 2008
            • 436
            MAF Connector loose / dirty?
            I had lumpy idle, stalling at junctions and general low rev issues but ran fine when approx 2000rpm+.
            Cleaned the connector and hey presto.
            • Jack4688
              • May 2010
              • 1004
              MAF was what I was thinking a few weeks ago when I got the odd flat spot. We'll see how it goes now I've got it back from it's extensive service
              • 4WDrifter
                • Nov 2012
                • 1251
                Damp in round the coil pack?
                1996 S2 ABY Coupe silver
                2003 S3 8L dolphin grey
                2014 RS4 B8 prism silver
