Banjo bolt fittings on 3b intake manifold size?
  • Josh-stateside
    • 741
    HI everyone.
    I haven't sourced my 3b intake manifold and fuel rail from europe yet. However I am trying to get a jump start on things. I am installing an electronic fuel gauge and I want to use a double banjo bolt setup if possible on the fuel rail.
    Basically I want to make that work on the fuel rail.
    Is it a 10mm?
    and if it's a 10mm is it:
    10x1.0
    10x1.25
    10x1.50
    Thanks
    Josh
  • s2avant
    • 2426
    Banjo bolts on the fuel rail of a 3B are M12x1.5
    HTH,
    Ben
    • Josh-stateside
      • 741
      thanks
      josh
