Gt42
  • bigcooler
    • Jan 2009
    • 229
    Gt42
    Hi guys I want to find out what would need to be done to run a GT42 with t4 flange.
    Thanks ben
  • Ruffiano
    • Sep 2007
    • 1458
    exhaust gases. that will run the turbo.
    Perhaps your question is a bit vauge... you might want to rephrase, perhaps include the type of vehicle and modifications already on the car.
    As a general rule if it is going on a 2.2 inline 5 turbo you will need strong rods, stronger pistions, to start, along with larger fuel pump(s), injectors, exhaust manifold, downpipe, ect ect.
    • bigcooler
      • Jan 2009
      • 229
      Sorry I have a stock aby running rs2 hybrid rs2 ex manifold larger injectors bosch 044 fuel pump and 4 bar map sensor And chipped standard ecu
      • driftin jo
        • Sep 2007
        • 2222
        If you have a healthy engine the minimum you will need is, con rods, exhaust manifold, big injectors, big downpipe/exhaust and obviously a remap.
        • bigcooler
          • Jan 2009
          • 229
          So I could run it with standard ecu (with a remap) and wont have to get vems etc? I have the 6 speed s2 gearbox also will that take the power? What sort of power will it produce?
          • V6quattro
            • Sep 2008
            • 949
            Wy do you want a gt42?? 900hp?
            1360kg/600Whp Avant 0-200km/h 9sec
            • bigcooler
              • Jan 2009
              • 229
              I dont have a valid excuse for that other than I have come in to one at a very good price and I LOVE IT
              • driftin jo
                • Sep 2007
                • 2222
                It will make 850-1000 hp depending on the options you choose for the GT42.
                Also you will need 2 044 fuel pumps.
                were you inspired by a recent video posting by any chance ?
                • bigcooler
                  • Jan 2009
                  • 229
                  It must have been a sign from god seeing the vid then being offered this
                  • V6quattro
                    • Sep 2008
                    • 949
                    If your happy whit 500hp or so just get a smaller turbo. If you like to run the gt42 at its full potential a lot of modification are needed.
                    • bigcooler
                      • Jan 2009
                      • 229
                      I would like to know what modifications I need to do to use the gt42
                        Are you talking about modifications just to physically fit that turbo to the EM and associated plumbing or what else needs done to extract the best from it.... In saying that it is better to look at the question from the other way - what are your hopes, requirements or expectations for a bigger turbo - lots of mid range torque or an all out screamer for maximum power ?
                        • bigcooler
                          • Jan 2009
                          • 229
                          Yeah sorry what I need to do to the engine etc for all out fun with this beast
                            I am not up to speed on that particular turbo but if you are aiming above 500bhp then you are looking at head work, forged rods, exotic pistons and much uprated fuelling. Stock MAF won't play there reliably either - you are looking at aftermarket ecu or someone like dmitri doing a custom tune with Hot film MAF. Big exhaust and intercooler are de rigeur too of course !
                            • bigcooler
                              • Jan 2009
                              • 229
                              I have a chip set of dimitri that im running so would be a problem carrying on with dimitri if he wanted to do it. Would it be nessasery to do a stroker? Or more efficient should I say
