remap trouble-project depending of it
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    Again me
    Here is my problem,i am thinking to do project on my urs4 on 500+hp,but...there is always but
    My main problem is remaping the car becose i live in Montenegro and here there is no ppl who can remap car(also no dyno)
    I also talked with prj and the nearest tuner is 1000km in 1 way,and the trailer would cost me 1600e+ so that option is off
    I post this with u guys to try to figure it out is there any solution abouth this?i know the there is generic chip for rs2 set up,but that hp is not enouf for me
    Is there any other option for biger hp (biger then rs2 set up) which dont need live maping,i mean option like rs2 set up?
  • bartolomeus
    • Jan 2009
    • 1475
    • Country: Romania
    Ask PRJ what turbo to get, injectors, fuel pump. Then he will send you a generic map.
    Get logging hardware, make some logs, send them to PRJ and he will make the final map for you.
    This is very time consuming.
    But I see no other option.
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      What's your total budget to spend?
      • bartolomeus
        • Jan 2009
        • 1475
        • Country: Romania
        Rocco will make you an offer you can't refuse
        For that kind of HP you are OK with holset HX 35 Super, fool boost at 3800 RPM, and I am sure PRJ has a basic map for that turbo.
        • pasbogdan
          • Sep 2009
          • 1160
          • Country: Romania
          If going with motronic 14point can offer wideband with boost that can be loged with motronic data in same log table.Also you can buy fuel pressure sensor from them and plug it to the controller and always know if your mixture is lean due to fuel pump or other problems
          Or aftermarket management,but you need to find the man who will get you generic sw,you make logs in different conditions and send online for adjustments.
          • Rocco
            • Aug 2007
            • 6393
            • Country: Spain
            In my pearl white S2 I had all this stuff
            But only fitted the EGT ,boost and AFR
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              He should buy your car and job done. Money and time saved
                Originally posted by Majorcina
                Again me Here is my problem,i am thinking to do project on my urs4 on 500+hp,but...
                You're just dreaming until you sort out your head gasket issue.
                Or I can suggest something "easier": for that kind of HP you will want to refresh the head and the headgasket so you better start with that.
                But then again, for that kind of HP you will want new, stronger, rods so don't put the freshed head back on until you've got the new rods (and maybe new pistons) installed.
                • bartolomeus
                  • Jan 2009
                  • 1475
                  • Country: Romania
                  I can sell you my engine, good for 480 HP, freshly rebuilt, it's on the car, you can test it, remapped by PRJ. With all the accessories included. Direct plug and play on your car.
                  • popdemonic
                    • Dec 2007
                    • 1304
                    • Country: Thailand
                    Marko,
                    As i told you need one either way.Live map,remote map,standalone.I think all tuners has the basemap provided for your setup.
                    Another option is getting 034 RIPCHIP but personally i had (off the shelf) chips kits from 034's.I'm disappointed.
                    one of a few I5 from Asia.
                    • Majorcina
                      • Jun 2013
                      • 1334
                      Dave i think i dont have headgasket problem?after i cleaned the maf car works perfecly,and i meaned to put stronger rods also becose this1 cant hold.This is what i planed to buy
                      -DM Forged H-beam connecting rod, set of
                      -I5 piston ring, priced each, OE goetze
                      -aan-head-set Aan upper end gasket kit
                      -aan-lower-end-set AAN lower end gasket kit
                      not sure abouth the turbo,manufold,injectors also i need biger IC
                      My curent budged would be 4000e
                      p.s. bartolomeus u have pm,rocco to
