Rotor arm problem?
  • LHD_Kid
    • May 2006
    • 3696
    Rotor arm problem?
    My car was not running well, mis-firing a little and difficult to start. Once started ran ok...
    What do you think the issue was?
    Originally posted by LHD_Kid
    My car was not running well, mis-firing a little and difficult to start. Once started ran ok... What do you think the issue was?
    Which century was the rotor last checked?
    • LHD_Kid
      • May 2006
      • 3696
      haha, this century, and not THAT many miles ago.... a lot less than 10,000 miles
      • simon20vq
        • Dec 2010
        • 1379
        Did you have a 12mm rota or 10mm fitted because I remember something about 12mm rota being wrong.
          Has to be the wrong rotor (or cap) then because that isn't normal.
            I think the proper rotor PN is 052905225C (10 mm).
            The proper 3B rotor was also used by Toyota and is a PN 19102-02020 according to the archives. Marc S. from EFI Express has also posted on here as how to trim the tip of a 7A rotor down to 9 mm width to help cure spark hop.
            Here is the thread. Unfortunately, Marc's photo has gone red [X]:
            • LHD_Kid
              • May 2006
              • 3696
              Yeah. Narrow tipped one.
              Not too worried as it will soon be converted to coil packs.
              I was just shocked to see this as car was running nicely until suddenly it didn't start properly.
              • s2driveruk
                • 12696
                Wow, that is toast!
                1992 3b S2 Coupe
                  • 4754
                  Grew up with points ballast resisters,rotor arms and never seen anything even remotely 1% as bad as this.The cars got gremlin eating monsters there my friend.
                  • denniselbows
                    • 740
                    I've had the same thing happen to me . It's amazing how the engine still runs with such a big piece of the rotor arm missing . Put a new rotor arm on and was all good again .
                    never set your expectations to high that way you are never disapointed
