Hi again, i need the ARP reference, if Anyone know please write.
(NEED) Removal head gasket s2 3b tutorial
1976 RD250E / 350LC cafe racerComment
Thank you.
Is possible install adu water pump on 3b? Aby or aduAttached FilesStep 1: setup.
Step 2: potentiation.
Step 3: enjoy.Comment
The 3B water pump is used as the cambelt tensioner so the mounting holes are slotted, the ABY/ADY pump is not, so the holes are not slotted.
The only was you can do it is to press the pulley off the ADU pump and install it on the 3B body. Not worth the hassle if you ask me.sigpic
