Unfortunately after changing numerous things to try and cure my poorly running RS2, it's coming down to possibly the compression being an issue.....
What originally started as just a rough idle is progressively getting worse as the car warms up, cylinders 3+4 seem to be the main ones affected.
Thinking it was a spark/fuel issue so far I've replaced:
New plugs
New coilpacks
Error404's wiring loom replacement
Injectors cleaned
So having discounted those, the next item is compression test, so I'm just waiting for my compression tester kit to turn up!
If it turns out the head has to come off, is it worth getting it refreshed while it's off (car has done 80K/miles), or anything else worth doing (porting etc)...if so any recommendations where to send it?
I only changed the water pump/crank pulley etc. not long ago when I did the cambelt, so they should be fine.
thanks
Chris
New plugs
New coilpacks
Injectors cleaned
thanks
Chris
and vice versa. Tis enough to shoot a tissue stuck in the plughole out the engine bay!
