hiya, I've been told by my new mechanic (i've ditched Audi due to the paaain!) that the RS2 is down on power so we got it dyno'd
here are the results (and some pics - video is still uploading to youtube , but not much to be seen there)
the guys running the dyno said out of 4 runs the car ran 2 different ways (this way below twice and 2 other runs at slightly lower power)
runs 2 and 4 are below. 1 and 3 were slightly lower.
- Power , 170kw at the wheels (around 18 > 20% drive train loss) = 204ish KW @ 20% loss
Jons (another RS2 owner in NZ) plot shows 270bp \ 201kw = 240kw+. @ %20 loss
My plot (blue isn't the best colour on black with this!)
So my power is down, my boost is down
Jons plot (he thinks it's OEM - it was before his ownership)
I'm not sure if 30kw can be found in 3 psi of boost?
Have flicked info to my mechanic
Prior to this run I'd had Audi (I'm reading off the many invoices in front of me...)
- replaced N75
- replaced wastegate actuator
- replaced vacuum lines
- replaced engine speed sensor
- replaced O2 sensor
- injectors out and serviced
and the new mechanics have
- replaced MAF with another 2nd hand unit
Hoping the greater 'Internet oracle' has some ideas?
Cheers!
John
- replaced N75
Cheers!
John
