will a aan [early s4] sump fit a car thats fitted wih a ur/s2 subframe , does it have same clearance as aby sump
AAN Sump question
Yes but the radiator wont fit in the stock position, the ABY has a bit pushed in on the side where the rad is. -
it's possible a AAN sump with side radiator
i lowerd my engine and machined the hole of the lower radiator support to the left
sie pictureAttached Filesaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injectionComment
