10v ur quattro steel sump
  • A1quattro
    • Jul 2006
    • 789
    has any one got one of these in good condition that they would like to sale a even swop for a alloy sump pls pm, are the us steel sumps baffled ?
  • caterpillar
    • 2480
    steel sump are NOT baffeled... but its easy to fix with some mecanic/ welder skills... all sump for the 5 pot fits...( warning; remeber the 2 ubrako( insex) bolt behind the flywheel)
    • caterpillar
      • 2480
      correktoins...the sumps fit the engine, so you have to know WHAT car the sump are for... small chassi; audi 80/90/s2,4000, and vw 32b-87... they DO fit in!!..
      • A1quattro
        • Jul 2006
        • 789
        THANKS CATERPILLER . do any people you know use a still sump on 20T
        • caterpillar
          • 2480
          no i dont; BUT i have alot of engine versons at home..., so i have the possible to test everything... i may have about 7 verson of the 5 pot...
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            by a steel sump there is a plastic baffle on the oil suction tube
            i have a steel sump and a suction tube from a old kv engine but thats in Belgium so..........interrested?
            TWINCHARGED power,zero lag
            AEM W/M injection
            • bluequattro
              • 2960
              I have a steel sump from a wr 10 valve I will sell if it's what you need
              • A1quattro
                • Jul 2006
                • 789
                seel sump
                thanks for your replys , i will let you know by pm if i req a sump............................ i realy want to here from anyone that has fitted one to a 20vt before i make my mind up . i could save an extra 2kg by fitting a steel sump instead of alloy but they can tend to leak oil at gasket [or do they]
                • caterpillar
                  • 2480
                  the audi 5 pot, the dont normally have a leak,, it the oilpump or seal in front are the weak point...all the older engine does have the steel one.. no prob... the 20v engine.. its only the headunit, who are the differnce...so if you does have an old 10v (MC1) or likely.. you may have the 20v headunit, with EM and IM.. and all the outer stuff... the bottom end are nearly the same....differnce comp and oilsquirter and like this...
                  • A1quattro
                    • Jul 2006
                    • 789
                    steel sump
                    think we are going to go with steel sump, what im thinking of doing is cutting the outter edge off the windage tray so it sits at top edge of sump rather than between sump and block , we will weld it to the sump or poss make 4 bolt fixings so it can be removed for future cleaning /inspection ,before this we will make some baffles to same spec as later aby alloy sumps . target is to save min 2kg , plus 25kg saved on alloy engine block , we have already save 2kg on new motec ecu loom, and hope to save 9kg on a new light weight lith 38 totalium battery 50kg is what i want to get car down to 1100kg
                    • A1quattro
                      • Jul 2006
                      • 789
                      the worst thing is the weight of a bare 20v cylinder head 16kg dare i ask any one know if all the 20v heads are same weight or any sensible ways of making it maybe 2/3kg lighter . i know im sad
                      • caterpillar
                        • 2480
                        plus 25kg saved on alloy engine block . do you have the alloy block???.... or i have seen the newer dieselengine in alloy coloured... BUT are they?? AXE engine.. fx
                        • caterpillar
                          • 2480
                          http://www.ebay.co.uk/itm/VW-T5-ENGI...item3f2cd4d5b9 ;are this engine in alloy????
                          • Kieron20V
                            • Mar 2008
                            • 1505
                            No, he has an ex-works alloy block. He has a thread somewhere I think.
                            Sent from my HTC One X+ using Tapatalk
                            1994 URS4 Avant RS2+
                            • A1quattro
                              • Jul 2006
                              • 789
                              hi all sorry im so rubbish on computers [and spelling ] yes i managed after years of looking ,,to find a alloy block its never even been used [yet] its currently having the oil ways drilled and a new set of main bearing caps being made. its a very late IMSA block
