Hard launch tickled the crank pulley
    I have a good AAN pulley / damper if required
    • philj
      • Feb 2010
      • 377
      After getting the front end apart, turns out the allen key bolts weren't torqued up properly on a cambelt job done about 10k ago in previous ownership. There was only 3 bolts in there, rest were loose. Pretty lucky really. The holes in part 3a are elongated, I got the new part today and it looks like one piece. From the top with the play and the vibration damper still/not wobbling it looked like the groves were a ring.
      Don't even want to ring VW to ask how much this is. This part number has been updated to another part with a shorter stub and a "diamond coated" washer which is some silly price.
      So if anyone has one of these without the cracks that would be great.
