Audi 90 with ABY NO START
  • Dan90
    • Dec 2013
    • 15
    • Home: Scotland Current: United Kingdom
    HI Guys wondering if you can help
    I have used S2 centrals guide on no starting but still having no luck
    I replaced the gearbox on my 90 5 cylinder I removed the engine to do this as I don't have access to a ramp
    I am getting spark to all 5 plugs have tested this visually with a set of plugs grounded to the head
    my fuel pump relay is not activation on crank
    I have checked voltage at the injector plugs and all have 12v when keyed on via ign switch
    and I have checked the resistance of the speed sensor which is at 982ohms
    I have also manual activated the relay and in pumps fuel and pressures up in the rail
    im currently charging the battery in case it isn't spinning over at the requires 23 rpm
    many thanks
    Dan
    also on a side not my clutch does not seem to disengage the clutch pack until right at the bottom of its travel have bled the slave cylinder so any help with this little problem too would be greatly appreciated.
    p.s. this was a running driving car before the gearbox swap was done
    Have you checked the hall sensor? ECU needs that signal to activate the fuel pump relay
    • Dan90
      • Dec 2013
      • 15
      ill check that now I thought it only needed hall sensor to get spark
      any other ways to test apart from just an ohms test?
        Use an LED to blink test the output on cranking
        EFI Motorsport is a company dedicated to providing quality upgrade parts, hardware, software, tuning, and service for a range of European vehicles.
        • Dan90
          • Dec 2013
          • 15
          have just done a slightly diferent test to test the signal voltage and I can confirm that the hall sensor appears to be working as it should
          • Dan90
            • Dec 2013
            • 15
            just a quick one I have just checked the fuses under the little red panel that says motor motuer and the 5 amp is blown on the right-hand side should this be a 5 amp and what do these two fuses control
              Yeah, sounds to me in that case that your ECU fuse is blown - 5A is not the right rating for any of the engine fuses!
              It needs replacing - the two "motor" fuses should be in S27 & S28 but might not be in the right place if is an engine swap - use the holder colour to identify them.
              Regardless of position, 5A is not the right fuse for any of them!
              ABY engine fuses should be as follows:
              S24 - blue holder - 10A (ISV, WGFV)
              S25 - red holder - 10A (lambda)
              S27 - brown holder - 20A (ECU)
              S28 - white holder - 15A (injectors)
              S32 - purple holder - 20A (coilpacks)
