Results of using the wrong C4 battery
  • sailaz
    replied
    Originally posted by UrS4boy
    Looks metallic = conductive, to me.
    yes, top side, which is not important. bottom side can have maybe 1cm of insulation material, and I assume that the one on photo has it
    replied
    Originally posted by YELL MAN
    This is mine
    Looks OE factory all right. Never seen a C4 rear seat with that though.
  • YELL MAN
    replied
    This is mine
    replied
    Originally posted by sailaz
    another solution, not on C4 but anyway
  • YELL MAN
    replied
    Hmm the underside of my seat has a layer of material covering the wire of the seat so the terminals cant touch any metal. It was on it when I got it.
  • sailaz
    replied
  • pasbogdan
    replied
    Originally posted by nimo781
    On a separate note, is this the most ridiculous design ever? What a place to put car batteries
    The solution is cutting the thin metal bar of the seat where it could get in contact with +.
    Anything on the + will make you get the seat out 3 times when you work there thinking:"did the blanket mooved?is it still in place?"
  • bartolomeus
    replied
    OMG what ****ed up news report...
  • marius555
    replied
    No need to understand the words ... i wasn't so lucky and the fire extinguisher was just 3 seconds of blast.... so .... be careful ...
    Citeste stirile de ultima ora de pe Observator News. Fii la curent cu ultimele stiri interne, externe, din sanatate, educatie, economice si politice.
    replied
    How come or from what you have decided that there was wrong battery used ? ?
    Because I have been on C4 Audi forums since 1998 and have made note of several such fires. In each case that I read about/saw, an incorrect (too tall) battery had been installed. Yes, that *might* not have been the cause in this case, but I would bet that it was.
  • Thuppu
    replied
    This is why you don't bolt down the seat. You can easily pull it out and ditch it.
  • Avantus
    replied
    Also had this with my typ44 100TQ MC2. Had the car for more than a year and went for a trip with 4 people on board for the first time. After only 200m the passengers in the back asked what that smell was and shortly after we saw smoke coming from under the rear seat. I was very lucky to have taken off the rear bench one week before to install a remote control central locking, and I had been lazy enough to leave out the 2 bolts that hold the seat since I was going to isolate my soldering work a bit more in the next weeks. If the seat had been bolted down the car would have gone up in flames for sure.
    Damage to the underside of the seat wasn't that bad luckily, but it was quite a shock
  • JP
    replied
    I always put an insulating blanket over the positive area ontop of the plastic cover as seen them wear through the cables too next to the cover. Happens even with the correct height battery if someone heavy sits on the seat as it flex's and bends down.
  • Guest
    Guest replied
    replied
    Wasn't intentionally trying to be nasty. I might have been perturbed that someone didn't see that it was an S6Plus (or late run UrS6 with an S6plus speedo) - which I do not own. They might not have know that. I guess I need to add my C4 holdings list to my forum sig here.
    NO worries, notwithstanding my comments, thank you for posting the thread and sharing your knowledge, as I have two urS6 C4s, with no battery covers.
    Currently both cars are resting, and so I've dodged a bullet so far, will be putting the covers on when they go back into service.
    Thanks again.
