7A wiring issues...
  • RS2
    • May 2005
    • 400
    Originally posted by Bowie69
    Apparently 800rpm, but I think the rev counter on most cars is pretty inaccurate, mine looks to be around 900, but any lower than that and it doesn't feel smooth.
    If you have a timing light with a tach gauge on it I would do that
    Ok thanks.
    I have a multi-meter with rpm read out that connects directly to the negative side of the coil so it's fairly accurate.
    I'll reset the idle as above instructions and go from there.
    Thanks again
    MG
