Greetings fellow adicts! Chips and Dip questions...
  • Boxerfan
    • Mar 2014
    • 24
    Hi all:
    I just acquired a 1990 Coupe Quattro with the 7A tricked out with 3B goodies and an RS2 replica turbo. The car has an unmolested 3B ECU... but I have code! :-D
    Not sure about how much to mod. Given the 7A has 10.3:1 CR and the RS2 can make big boost the stock chip may be all I dare to use. I know one chip is a 27C256. Are they both the same? or is one a smaller 27C128 or 27C64? Are they both already socketed? The old MAC11 units were soldered in place and with the conformal coating a real mess to remove. I am new to these Audi models and like to be sure before I poke at things too much.
    So, for that matter, has anyone here done the RS2 on a 7A with the 3B goodies around here who can share some knowledge?
    Cheers and TIA;
    Boxerfan
    North of Toronto, Ontario
    Canada
  • andy10v
    • 5996
    Double post edit
    Sold ABY-stock
    • andy10v
      • 5996
      3B ecus are normally socketed from the factory, ABY/AAN/ADU normally not as far as I know. Easy enough to open the case and confirm though.
      You will need a new map sensor, normally 3 bar to run the rs2 turbo to its potential.
      I think you will be pushing your luck running an Rs2 turbo on a stock 7a though.
      You wont be able to use a stock RS2 chip set if that is what you are asking, as the RS2 was a coil on plug (like an AAN/ABY) rather than distributor setup, so different ecu.
      You would also need RS2 injectors, and whatever fpr the chipset calls for, though finding a 3B RS2 chipset for a high compression engine but low boost sounds challenging.
      Sold ABY-stock
      • Boxerfan
        • Mar 2014
        • 24
        Actually the 2 main questions there are:
        1) what are the chips required for the 3B. I want to keep the originals and play with a spare set with various code adjustments to actually lower the boost across the board so I avoid detonation and can stomp on the go pedal.
        2) If anyone has run a similar setup what did they end up doing to prevent detonation with the Turbocharged 7A
        My other car is a monstered 10VT running an RS2 Turbo in a rally livery Ur-Q. CIS was recently ditched in favour of a MS system so I can find the limit for the build. The CIS wasn't up to the task AFAIK. I have the RS2 injectors for it, come to think of it I think this 7A has the RS2 injectors as well.
        • K Simmonds
          • Dec 2007
          • 7627
          Your 10 valve build sounds interesting do you have a build thread for that car anywhere on the net?
          I'm running a full RS2 set up on a 3B with a stock ECU, well the turbo's an RS2/K26 hybrid, I found RS2 injectors with the 3B's 3 bar fuel reg give nice safe AFR's on boost and bang on 14.7 off it. That's using stock 3B software which with the original 3B items made it run a touch on the lean side especially on WOT. This is only a temporary arrangement, the car is going to live mapped fairly soon.
          As your motor has a fair bit extra compression you want to make sure you do have some bigger injectors than stock fitted, sounds like another interesting project.
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
          • Donald Smith
            • Nov 2007
            • 70
            Hi Boxerfan. Welcome. I live north of Mtl, and have RS2 injectors if you need them.LMK.
            Don
            Oops, sorry, I just saw that you have these already.
