MAF to K26/27Turbo hose restriction?
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    GTM will probably have the70mm hose back in stock by the end of april, maybe bit later.
    Waiting for Roose now.
    • Avantus
      • Sep 2007
      • 941
      • Country: Belgium
      Paul from Roose mailed me that he can deliver the hose with 70mm inlet for the K26/27 turbo's.
      Asked him how much and how long it would take
      Keep you guys posted.
      • lcsmith
        • Jul 2007
        • 477
        I'd be interested in one
        Audi A4 (B7) 2.0 Tdi (140PS)
        Audi 80 (Typ 89) Quattro 16v
        2 x Audi URS4 2.2 20v Turbo
        Audi 100 (C3) Quattro 2.2 10v Turbo
        Audi 100 (C3) 2.2 10v Turbo (Auto)
        Audi 200 (C3) 2.1 10v Turbo - Scrapped
        2 x Audi 80 (Typ 89) Quattro 1.8 8v - Scrapped
        • Avantus
          • Sep 2007
          • 941
          • Country: Belgium
          Incl shipping to Belgium it is 160gbp, so should be a bit less to the UK. Around 2.5-3 weeks waiting time.
          • Wrath
            • Jan 2011
            • 779
            from the US ? my good... I have to add 32% on that total price thue to custom hmm...
            1995 Audi S6 - AAN (~350hp)
            2008 BMW 530xd (235hp)
            2011 KTM 990 SMR - custom tuned (120whp)
            • Avantus
              • Sep 2007
              • 941
              • Country: Belgium
              #21
              No from the UK
              I'm waiting for GTM to give a price, should be less...
              • SteveH
                • 4460
                I have this hose and it's a modified standard hose. It's a 70mm connector to the turbo but has the original size inside. The hose also badly interferes with the bodywork by the rear of the headlight. I will post pics of the restriction and issue with clearance.
                91 Modded 3B
                14 A6 Avant Black Edition
                • Avantus
                  • Sep 2007
                  • 941
                  • Country: Belgium
                  #23
                  Hmm that isn't ideal then indeed.
                  This is GTM their 70mm hose, much better:
                  • prj
                    • Mar 2010
                    • 6308
                    I think you are searching for problems where there are none
                    As long as it's bigger than the turbo inlet, I don't think there's any measurable restriction.
                    • Wrath
                      • Jan 2011
                      • 779
                      I wonder if that will fit my AAN stock air, then it would be ideal for me as my stock hose dosent fit my K26/27 turbo Don´t want to use open airfilter thue to dusty enviroment and heatsoak...
                      • Wrath
                        • Jan 2011
                        • 779
                        Have you got a quote on the GTM hose and if it´s in stock?
                        • Avantus
                          • Sep 2007
                          • 941
                          • Country: Belgium
                          #27
                          With the metal ring inside I think it slightly smaller, but the question is indeed if the slight non-smooth path the ring causes is giving anything measurable to think about.
                          • Avantus
                            • Sep 2007
                            • 941
                            • Country: Belgium
                            #28
                            as posted above I'm waiting for the quote, and should be in stock by the end of april.
                            Previously they were around 130€ I think.
                            • Wrath
                              • Jan 2011
                              • 779
                              Okay, thanks
                              • lcsmith
                                • Jul 2007
                                • 477
                                Hi guys,
                                I've got a standard Roose boost hose kit and I'm fitting a K26/27 so I'm looking to make an adapter up.
                                I thought that using a 70-54mm (ID) straight reducer with a piece of metal pipe between the reducer and boost hose would be the cleanest install.
                                Due to the space restriction the straight reducer would need to be shortened, which wouldn't take long with a knife...
                                For an idea this is the thing I was thinking about;
                                http://www.ebay.co.uk/itm/1710924720...84.m1423.l2649
                                Anyway looked into buying the reducer and I can't find a 70mm to 54mm anywhere! They make 70-51mm and 70-57mm but not 70-54mm!
                                Any ideas if it's available anywhere, maybe I would need to contact roose / samco directly...?
                                Leigh
