Rad shafted again!!!
  • GT500
    • Jun 2006
    • 2181
    Just found my beur radiator is leaking from where the top tank meets the aluminium. Its not done 40k and still looks like new. Not impressed.
    Noticed winner racing on the bay do an all ali one for £200. I have used one from them on a clio cup car and works great.
    Long ago i made new top and bottom tanks for the beur one in ali but when the weld cools it cracks. Must have lots of magnesium in it hence the cool down cracking.Might try one, anyone else tried them?
    Here
    Rob..
    87 UR 20v ABY
    97 S6 Avant
  • AndyP
    • 6049
    Check with Danny @ DNA, he's put a Chinese alloy rad on Jamo's od car and said the quality was poor, it leaked out of the box!
    • K Simmonds
      • Dec 2007
      • 7627
      My nearly new Behr rad is doing the same thing from the bottom end tank/core seal, only very slightly but leaking non the less. I was going to see if my local rad place could repair it but I've also been eyeing up alloy rads, not sure I want to buy another Behr and all the other options are rubbish.
      I'd be up for an alloy rad group buy if we could get a few of us together.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • s2driveruk
        • 12696
        that looks promising, will be keeping an eye on this if you do go for it, mine is coming up for 15years old (behr) so will need to be replaced soon I'm sure
        1992 3b S2 Coupe
        • GT500
          • Jun 2006
          • 2181
          I don't mind if it leaks on a weld. As long as it can be welded I'm ok.
          I think I'll order one and report back on how I get on.
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • K Simmonds
            • Dec 2007
            • 7627
            Be interested to hear your opinion of it, looks OK for the money.
            1994 MTM RS2.
            2000 B5 TQS.
            • mac2226
              • Jun 2008
              • 1289
              I'm in same situation rad has seen better days I've got a friend who does alloy welding a lot and I'm going to get him to make me a custom radiator with a thicker core
              • GT500
                • Jun 2006
                • 2181
                Fitted the Winner racing rad last week. All good. You just have to drill the mounting holes for the fan and other covers etc that bolt to the rad sides. Bottom and side mounts are there. As are the hook brackets for the ac condensor.
                No leaks and pleased with the quality.
                £189 took a week to arrive. Bargain.
                Rob..
                87 UR 20v ABY
                97 S6 Avant
                • rynaqui
                  • Mar 2012
                  • 2752
                  • Country: Malta
                  Done about 10k so far on my Nissens, not confident though..
                  1996 S2 ABY Silver
                  • quattrostyle
                    • Oct 2006
                    • 6229
                    Hope it holds well Rob, looks quite nice.
                    • sidrick
                      • Jan 2011
                      • 1342
                      Does it have a take off for the aux radiator?
                      • GT500
                        • Jun 2006
                        • 2181
                        It sure does. I didn't need to add any take offs. Just the mounting holes to drill.
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                        • cooperquattro
                          • Jan 2011
                          • 815
                          Is the winner racing rad still ok,as I am looking to buy one in the next week or so,any improvements in cooling????
                          Also going to try one for my mx bike
                          • GT500
                            • Jun 2006
                            • 2181
                            Yes all good still. No issues through the hot part of the summer.
                            I got a pair for my mx bike at the same time.
                            Rob..
                            87 UR 20v ABY
                            97 S6 Avant
                            • s2driveruk
                              • 12696
                              i noticed recently they did one with a 70mm core depth, I wonder if this is a better solution for those deleting the aux (as I have) or whether the standard one you fitted Rob is more than efficient enough over the stock Behr unit???
                              1992 3b S2 Coupe
