High tick over/juddering
  • bilko0795
    • Feb 2011
    • 1883
    Used the car this morning running as it should on leaving for work I started the car and it felt rough the revs were low, revved the car up seemed lumpy I drove of and it started to kangaroo was only doing 10 mph when I stopped the revs were on 1400 rpm and they won't drop below that. When I accelerate it drives ok the boost gauge only reads 0.2 bar when I accelerate hard but as said it drives ok. Coming home tonight had the same erratic running doing 10 mph was really violent. Would I be right in thinking it,s the dreded boost leak or something else with the engine running on high idle.
    Have you pulled the codes? Sounds to me like you have a large boost leak
    • bilko0795
      • Feb 2011
      • 1883
      Can't pull codes yet had a tantrum couple of weeks ago and smashed up my laptop and the wife went and bought an iPad don't know anyone who as a laptop all my mates have iPads will start looking this morning.
      • 220bhp
        • 2578
        • Home: United Kingdom
        Check for vacuum Leaks, including the pcv hoses
        • bilko0795
          • Feb 2011
          • 1883
          Will do, I have just ordered a sealey test kit should be here on fri/sat just got to get a compresser from b&q and away we go.
          • 220bhp
            • 2578
            Make sure the neighbours aren't watching, and just pull the vacuum pipes of the back of the inlet manifold one by one, suck, and put your tongue on the pipe, if it holds your
            tongue it holds vacuum You will need the pressure test kit and compressor for the other pipes.
            • Rusty
              • 18953
              One way valve?
              take the pipe off the underside of the inlet and bung it at both ends.
              • bilko0795
                • Feb 2011
                • 1883
                Will try that method
                • bilko0795
                  • Feb 2011
                  • 1883
                  Originally posted by Rusty
                  One way valve?
                  I will Also try this as I have just bought silicone vac pipe to replace old ones
