2.6 cabriolet ecu change problems
  • 220bhp
    • 2578
    • Home: United Kingdom
    I have just tried changeing the ecu in my wife's 2.6 cabriolet in an attempt to fix some running issues. The original ecu is part no 4A)0 907 473D, and the other one is 40A 907473k.
    I fitted the ecu and the car started then died. Is this the key code or immobiliser possibly.
  • veneto rs2
    • Jun 2006
    • 1022
    • Country: Veneto
    I believe that it could be the immobilizer.
    Had the same issue with a noncoded spare key.
    Stefano
    http://www.audisportclub.com/
    • veneto rs2
      • Jun 2006
      • 1022
      • Country: Veneto
      Just had a check on KATE and definetely the two ECUs should be the same.
      Accordingly with KATE one it's the substitute of the other hence should be fine realted to the ECUs.
      Immobilizere once again IMHO
      eliminato il 01/05/2000 usa come sostituzione= elimiminated 01/05/2000 use as substitute....
      • 220bhp
        • 2578
        Thanks for the information. How do I get the new ecu to work.
        • veneto rs2
          • Jun 2006
          • 1022
          • Country: Veneto
          No idea but I advise you to drop a PM to "prj" if there's somebody that knows everything about ECUs that's him for sure"
          Otherwise go to Audi dealer.
          I had a friend that changed an RS4 ECU and eventually Audi dealer recoded ECU to immo.
          Same behaviour as yours.
          • spink
            • 4382
            what year is the car?if its pre 95 you will probably find it is a non immobilised car which means fitting the K ecu (which is from an A4) will never work without some wizardry inside the ecu.
            If its 95> it should be easy to reset it to work using vagcom
            • 220bhp
              • 2578
              The cabriolet is an N reg. the other ecu cam.e from an R reg.
              • spink
                • 4382
                easy enough to do with vagcom then
                seems the K is used on a4 and cabrios so shouldn't be any issue with it,only thing I have heard is some of the ABC v6 ecus were 145bhp instead of 150.No idea which ones and even if it was a UK thing or not,iirc spain had some
                • shaun5
                  • 1610
                  if you get stuck ive got 3 or 4 ecu's from V6 cars
                  • 220bhp
                    • 2578
                    • AndyD
                      • Sep 2011
                      • 323
                      Out of interest what was the original running problems you had that made you go for a new ECU?
                      • 220bhp
                        • 2578
                        The running problems are. Starts, but stops about half a dozen times, hot or cold. Runs lumpy at times. Seems to run rich. Poor fuel economy. exhaust smells. poor tick over sometimes.
                        Things I have done. Two different sets of fuel injectors . new plugs, and leads. new ignition module etc. Replaced idle control thingy. New thermostate. New FPR. New fuel filter. New cats and exhaust. Replaced Lambda sensors. checked vacuum lines. Cannot read codes. So thought Ecu might be the problem.
                        The car belongs to my wife, who drives it in top gear all the time. Runs it on cheap petrol, when she dos put petrol in, otherwise it runs on fumes, cant tell her she wont listen.
                        • shaun5
                          • 1610
                          Ive got 3 X 2.6 V6 engines that were all running before I scrapped the cars. Doesn't sound like you have got much left to change but if you need anything send me a pm
                          • AndyD
                            • Sep 2011
                            • 323
                            Mmmm ........ Considering how much you have changed and it's still not right I would be considering an issue with the throttle body or ECU
                            • spink
                              • 4382
                              Knock sensor?
