S2 ABY loses power over 4000rpm
  • rxl
    • 1913
    how mutch boost do you get ???
    • Alticity
      • Jul 2011
      • 17
      • Country: Norway
      1,3bar have a pressure gauge in one of the airholes in the car. If i try more boost it only goes in "security mode". So it goes in security mode before i hit 1,5 bar.
      N75 is not in use.
      • rxl
        • 1913
        N75 is not in use.
        stupid question but what are you using instead of n75?
        • Alticity
          • Jul 2011
          • 17
          • Country: Norway
          I use a manuel boost controller from turbosmart, like this one: http://www.turbosmartusa.com/product/boost-tee
          + i have a Forge resirk valve.
          But the N75 is still connected.
          • rxl
            • 1913
            so your using your stock ecu map with this mechanical boost controler?
            • Alticity
              • Jul 2011
              • 17
              • Country: Norway
              #21
              Yes, but i have mtm 303 chips and a varimap mapsensor from 034.
              Isnt this okey?
              This is normal thing to do in norway.
                Yes, but i have mtm 303 chips and a varimap mapsensor from 034. Isnt this okey?
                I would say NOT okay. You have a good set of chips but you aren't letting them control the engine the way they were designed to do. The manual boost controller (MBC) is overriding the chips, at least at the upper end, where you think you are having problems.
                Strongly suggest that you remove the MBC and make sure that the N75 is hooked up properly.
                Have a read on this N75 Post:
                Typical MBC installation - yours might have issues anyway:
                • GazzaG60
                  • 4133
                  mbc is never good in imo. ebc yes, mbc no.
                  sounds like you should be using motronic though with that chipset
                  • Alticity
                    • Jul 2011
                    • 17
                    • Country: Norway
                    #24
                    Do you guys think this can be the reason for loosing power over 4000rpm?
                    • Alticity
                      • Jul 2011
                      • 17
                      • Country: Norway
                      #25
                      When i bought the car couple of years ago, the car was going like ****. Then i bought i boost gauge and it showed 0,6 bar.
                      Then i bought a mbc and a forge resirk valve then the pressure came up to 1,2-3 bar.
                      Was the n75 broken then?
                      Should i buy a new n75 and do it the original way again? J or H n75?
                        Definite maybe. Strongly suggest that you remove the MBC and make sure that the N75 is hooked up properly both hose-wise and electrical connection-wise and then "test" your car again.
                          When i bought the car couple of years ago, the car was going like ****. Then i bought i boost gauge and it showed 0,6 bar. Then i bought a mbc and a forge resirk valve then the pressure came up to 1,2-3 bar. Was the n75 broken then? Should i buy a new n75 and do it the original way again? J or H n75?
                          Classic post. Part way through a "HELP ME MY CAR IS BROKEN" thread, the poster finally decides to disclose the complete story, after wasting several people's time trying to figure out the problem based on partial truths, not the complete story.
                          0.6 Bar = the N75 isn't hooked up OR the boost line to the ECU from intake manifold to the MAP sensor in the ECU isn't hooked up properly OR there is a leak OR the N75 is fubar'd.
                          Have fun. I'm done. Maybe the next sucker will help you.
                          • Alticity
                            • Jul 2011
                            • 17
                            • Country: Norway
                            #28
                            Im sorry, i was asking alot in the norwegian audi forum. And there i was told everything was okey about this n75 ****. So I think it was irelevant!
                            Thank you for your time!
                            • quattrostyle
                              • Oct 2006
                              • 6229
                              Don't worry, try the original setup with the N75 and let us know if it solves your problem.
                              • rxl
                                • 1913
                                i got time for these kind of stories
                                connect your n75 and you will see whats the problem...
