yea as you can see its very cramped in there, length is 4.5cm and width is 3.3cm
Looking for 3 bar map sensor, help!
No you can't without a new chip that takes the map sensor into account.
Originally posted by grundeyCan I change my 2bar map sensor to 3bar in 3B engine?'98 Silver Grey 2.7T S4, dual 2.75" turbo back exhaust with no cats, FMIC, BIG injectors, 10 Bar motorsport fuel pump, modded RS4 turbos, tubular exhaust manifolds, custom intakes, RS4 MAF, Bilstein PSS9, H&R ARBs, 19" BBS CH, custom remap, 511 BHP/505ft-lbs
www.MRCTuning.com
info@MRCTuning.com
Workshop DirectionsComment
Maybe you know where I can buy this chip and also 3bar map?Originally posted by MihneaNo you can't without a new chip that takes the map sensor into account.
If I buy GREDDY map, will it fit and run properly with MOTRONIC?
cheers
RogerComment
