RS2 spark plugs
  • handy andy
    • Oct 2008
    • 149
    RS2 spark plugs
    Hi All,
    I'm just about to change my plugs on the RS2 and did a quick search to see what other people are using,to find a lot of conflicting info' regarding the original Bosch F5DPOR which are in the car now.
    So what are you using in your RS2's or RS2 spec cars??
    Andy
  • Ross
    • Aug 2005
    • 3399
    It seems to be between these and the NGK's that are a bit cooler - all detailed in the threads I'm sure you've read.
    Personally I'm still running stock on my RS2 with hybrid turbo and 2.1bar without any issues. I might give the others a try some time and see how they compare.
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      I've heard people had issues with Bosch plugs, I changed mine to new F5DP0R about two years ago purchased from EFI express, they seem ok and seem to handle RS2 power (chipped) just fine
      Not sure what really causes the failure or maybe the ones that experienced failures were just a bad batch?
      1996 S2 ABY Silver
      • A80Avant
        • 10873
        • Country: Greece
        I will be changing mine to bosch DRC as per EFIEXPRESS in the summer. I have a fresh platinum on now but don't trust them anymore. Must have been some poor batches.
        • 20Vcqdriver
          • 829
          Been using the NGK recommended PFR7B for the RS2 in mine at 400bhp without issues though regapped to 0.6mm
          1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
          • sailaz
            • Oct 2009
            • 647
            • Country: United Nations
            hmmm, what about NGK BKR7E-11 ? maybe somebody has experience with these ones ?
