If the engine runs we have to assume that the relay is ok as both the injectors and these components are fed power from the same contact within the relay but have seperate fused supplies.
So that leaves the connection between the relay and the fuse, the fuse, and the wiring from the fuse to the connectors to the components.
We can test for power (12V+) or continuity. For example you can see if there is power at the fuse by probing the metal top and earth or test for contnuity by measuring continuity across the metal strips at the top by using the OHMS setting not the voltage. If it reads 0 Ohms its ok, if it reads 1 it is blown.
Don't forget it needs to be with the engine running to get voltage readings but not continuity.
