Will this fit our engines?
  • gnutz2
    • Aug 2006
    • 928
    http://www.ebay.co.uk/itm/SEAT-LEON-...item5407760e2a
    The ONLY S2 Golf!
    10.42@138mph
  • diesel des
    • 3896
    Not on an ABY or AAN as no cam position sensor setup.
    Sent from my GT-N7105 using Tapatalk
      G40 Cam Position Sender Shutter Wheel info
      No on an AAN or ABY or ABU. What you would want is an adjustable cam sprocket that also has adjustments for the cam shutter wheel on the back of the sprocket.
      Stock AAN and ABY sprocket and shutter wheel showing the relationship between the G40 shutter wheel opening and the stock cam timing mark.
      Here is one fromTommi's showing how both outer cogged wheel and the inner shutter wheel are adjustable:
      Here is the back of Tommi's shutter wheel showing the ends of the machine screws used for the adjustment.
      • A1QSHIP
        • Aug 2004
        • 975
        How critical is the G40 camshaft sensor timing to crankshaft timing? I realize that it needs to be within a certain range. Can this value be optimized? Other than using a dual channel oscilloscope & comparing the signals between G40 & G4 crankshaft position sensor, how would one check it?
        TIA, Chris
        "Nulla tenaci invia est via"
          Originally posted by A1QSHIP
          How critical is the G40 camshaft sensor timing to crankshaft timing? I realize that it needs to be within a certain range. Can this value be optimized? Other than using a dual channel oscilloscope & comparing the signals between G40 & G4 crankshaft position sensor, how would one check it? TIA, Chris
          That's probably the only way. That and an adjustable cam sprocket like that from Tommisbillet.com and a dyno. Sounds like fun.
          In the interim, all I can add are these (AAN/ABY vs ADU cam shutters) (remembering that the ADU intake cam is "twisted" 10 degs from the AAN/ABY intake cam positions):
          • A1QSHIP
            • Aug 2004
            • 975
            Subscribed!
            Thanks, Chris
            • A1QSHIP
              • Aug 2004
              • 975
              delete
              • gnutz2
                • Aug 2006
                • 928
                Thanks for the replies
                Maybe I should have mentioned I don't run a g40 cam sensor. So knowing that it should fit then.
                I suppose even if the timing mark was in a different position on the vw engine I could put my own on it.
                The ONLY S2 Golf!
                10.42@138mph
                  Yup.
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    i have a AAN engine with g40 sensor on the back of the head and looks like a distributor so this wheel can fit for me i think
                    TWINCHARGED power,zero lag
                    AEM W/M injection
                      AAN G40 Hall Effects Cam Position Sender Mounting locations
                      Tuna can boy!! Any chance you can tell me the AAN number on the head, exhaust side, near the front, i.e. AAN000nnn?
                      • quattro-nick
                        • Sep 2012
                        • 1746
                        • Country: Belgium
                        thats the one yeah,if you want i can take a look tomorrow
                        the engine is from a audi 100 s4 c4 92'
                        AEM W/M injection
                          thats the one yeah,if you want i can take a look tomorrow. the engine is from a audi 100 s4 c4 92'
                          As far as I know the transition to the front of the AAN occurred in mid-Feb 1992 so all the early 1992 S4 AANs had the intake cam-driven "tuna can" dizzy with the G40 inside. If you ever need to replace it you can use the pdf that I created, linked below. In the interim, I am curious about the engine number to add to the data bank of before and after the transition.
                          • quattro-nick
                            • Sep 2012
                            • 1746
                            • Country: Belgium
                            if i find the number,i will let you know
                            this is the chassis nr of the donor car
                            WAUZZZ4AZNN078290
                            p.s. nice info of hall sensor replacement
                            AEM W/M injection
                              WAUZZZ4AZNN078290 p.s. nice info of hall sensor replacement
                              NN78290 was probably built in the first week of January 1992 so I would have guessed that it would have had the "tuna can" G40 dizzy. *BUT* I would still like to see the SN of the engine like this:
