Valves diference 7A and AAN head
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    I recently buyed 7A head from forum member (Rocco),and i finaly found a guy to convert it to AAN,i have been told that i need to change valves from 7A head,but now i got problem,3 valves from my AAN head are bended(2 on exhaust side)
    So my question is,can i use those 3 valves from 7A head?Will they work normaly?or they will **** up my engine?Or the last option is to buy new valves?
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    The intakes are the same....the exhausts not.
    I suggest buy 2 new OEM exhaust valves...
    Goodluck!
    • 220bhp
      • 2578
      • Home: United Kingdom
      Gas filled valves on all turbo charged 20v, and some 7a
        Umm...not gas. Sodium (a solid that absorbs heat and goes to liquid, not a gas)-filled.
          Some of the 7A exhaust valves were sodium, even though the parts system suggests not. No pattern to it, I suspect whatever was in the parts bin at the time was used. The only way to tell is to weigh them.
          FWIW I would just fit new ones, the consequences of a failed valve are pretty expensive
            I suggest buy 2 new OEM exhaust valves... Goodluck!
            I was pretty sure that we had determined that some 7A exhaust valves were sodium filled (maybe the early ones with the bag-o-snakes header) and only the later ones were not. 3B/AAN/ABY/ADU exhaust valves (611B) were/are sodium filled.
            Here is a complete thread on the topic:
            • Majorcina
              • Jun 2013
              • 1334
              So what u suggest me to do guys?
              • Pirvu Eugen
                • Apr 2007
                • 1978
                • Country: Romania
                I am sure you are right Dave....but...i have dismantled few 7A's and 3B AAN engines and, from my experience, none of the 7A's i dismantled had the sodium filled valves.
                The best is to look at the pn from the valve stem to be sure. BTW, i suggested to buy OEM ones as all the aftermarket ones sold here as correct for the turbo engines were infact NOT sodium filled...
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  Ahh...and btw...the last 7A engine i dismantled had the snakes exhaust manifold and not sodium filled valves. I know this as i used 1 of those for testing. I cut 1 3B and 1 from that 7A engine.
                    I would either buy new valves from the dealer (using the proper PNs) or find a dead AAN/ABY/ADU head (one with cracks), buy it and use it for parts.
                      Kolbenschmidt part number for sodium filled exhaust valves is 33050 - around £13 each
                      HTH
                      • Majorcina
                        • Jun 2013
                        • 1334
                        Shud i buy those 3 new?It wont efect on anything?
                        • Pirvu Eugen
                          • Apr 2007
                          • 1978
                          • Country: Romania
                          I think the best will be to buy new just the exhaust ones...the intakes are the same.
                          Goodluck!
                          • Majorcina
                            • Jun 2013
                            • 1334
                            Any link where can i buy them?
                            • Pirvu Eugen
                              • Apr 2007
                              • 1978
                              • Country: Romania
                              Go at Audi dealer near your location and buy 2 new exhaust valves with the correct pn.
