Ignition Hesitate
  • S2sedan
    • Aug 2004
    • 189
    Ignition Hesitate
    Hi,
    My car just got ready from my last upgrade.
    T04E 57 - hot side RS2 with 60" rotors, Running on ethanol.
    1St question:
    Does anyone knows which RPM should I see full boost (1.6)
    2nd
    Have a little hesitate in some revs. (ign. Hesitate) Does Golf or A3 1.8T coilpacks are compatible with S2 ? I think that some ig. sparks may scape by the black rubber.
    (At least that black rubber tube that conects coil to spark plugs) don´t know the name of it.
    S2 Limo sold !!!
    M5 E34 with some mods in the garage
    sorry, but much happeir now !
  • S2sedan
    • Aug 2004
    • 189
    no one ???
    S2 Limo sold !!!
    • Mihnea
      • 1288
      Full boost RPM depends on your chip and on your turbo. if the hot side is a #6, you can have full boost around 3000 RPM with lots of surging up to 4500 RPM at 1.6 Bar on a stock head with stock cams.
      The ignition issue could be the ECU telling you "WTF" because something might be off there...
      Mihnea
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
