i'm planning to delete the one way valve under the intake manifold since i'm planning to install the catchcan and swirlpot when i connected the vacuum hose from the port under the intake manifold to N80 Charcoal canister valve(which currently it's working as only a check valve since i have VEMS and i have not yet wiring the analog output to control the N80).once i tried to block off this port or plug on the N80,the engine stalled so how can i delete the small one way valve since it seems the engine needs to breath via this port and ISV when the throttle is closed on idle.anyone has a diagram on how to install the catchcan and remove the one way valve?
How to delete the one way valve under the intake?
Tags: None
i have removed the one way valve and n80 valve and block the connection off under the throttlebody
afterwords you can change idle settings in vemsaudi coupe quattro b2 2.2 20vt project (573hp-626nm)
TWINCHARGED power,zero lag
AEM W/M injection -
Yes, you cannot just leave the hole where the 1-way value was open, as this enters the system post MAF, so will make the car run incorrectly.
Run a pipe directly from the top of the swirl pot to the inlet hose (AAN) or to the pipe that runs through the cam cover (ABY/ADU).Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
