Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!????
  • Albie S2
    • Oct 2004
    • 138
    • Country: South Africa
    Hi
    I need help here,i have a 91 s2 3b and this thing is driving me crazy first thing is when i accelerate the boost gauge indicate 0.9 bar and as soon the car start performing well the boost drop to 0.5bar and then at 5000rpm it the boost is 0.9 bar again this happen in every gear.I started to pull the error codes and 1 is carbon canistor valve that is no more there and the other is lamda sensor,now lamda sensor wont limit the boost due to it will overfuel but if i bridge the carbon valve i here something in the front of the turbo clicking now when i accel i also here this clicking by the valve at the turbo can any1 help here.
    thks.
    www.cardomin.com/member/745893
  • S2 Ant
    • 3682
    The clicking would be the WGFV i believe trying to control the boost.
    I would think this is a leak and its trying to prevent the turbo being overspun.
    Check your hoses I think
    Ant
    2011 Kawasaki Z1000
    • Albie S2
      • Oct 2004
      • 138
      i have checked all the boost hoses no leaks at all.
      • Honahon
        • 90
        how have you checked the hoses mate?
        SOLD.. :(
        But now proud owner of Porsche Boxster S.. :fire:
        • porkkis
          • 1994
          Standard or chipped?
          Replace the lambda.
          Try unplugging the carbon canister valve. Get rid of that fault code.
          Could be also the ambien pressure sensor. At what altitude did you test?
          • Albie S2
            • Oct 2004
            • 138
            Ok replacing the lamda sensor is a bit difficult because i am from south africa and audi doesn"t have spares on the s2 and secondley there is no carbon canister valve anymore only the electrical plug and the pipe out of the back of the cyl head is blocked off,can i bridge the two point on the plug?
            • Albie S2
              • Oct 2004
              • 138
              sorry its standard and the altitude is about 1200m above sea level.
              • porkkis
                • 1994
                Get any 3 wire bosch lambda and replace the connectors from the old one. DO NOT SOLDER THE SIGNAL WIRE.
                Dunno if you can short the canister wires. I would't try that. I presume it has nothing to do with your problem but these are mysterious vehicles...
                • Albie S2
                  • Oct 2004
                  • 138
                  Ok i will try to get a A4 lamda sensor and put it in see what will happen then.Does this mean that the lamda sensor can limit the boost at a certain rpm range.
                  • porkkis
                    • 1994
                    No but a faulty sensor messes up the mixture and might cause detonation and that's prevented by adjusting the boost and ignition timing, right?
                    • Doug_RS2
                      • 3847
                      Why?
                      • porkkis
                        • 1994
                        I guessed you want to know.
                        The answer is quite unbeliveable so I'll leave this explaining to someone who can do it in mother tongue. Hopefully someone knows.
                          huh
                          • kwlw
                            • Sep 2004
                            • 1025
                            • Country: Lithuania
                            Stupid idea - just try to pull control hose from wastegate with some moderate force (like 2-3kg). Sometimes this hose is leaking, however, clamp, and hose itself look ok.
                            I've seen this effect on unchipped 3b. When you accelerate hard, boost comes to 0.9 bar, and ecu cuts fuel or something. However it always said "overboost error" or something like that, so it may not be your case. But it still worth trying anyway
                            Sau
                            • Albie S2
                              • Oct 2004
                              • 138
                              Ok but it does"nt give any error codes of overboosting!!!
