I think some calibration is needed. I also have some LMM's (AMM) purchased for the bargain from ebay, however they will reach me after several months.
The Idea was to calibrate these LMM by example from existing 3b AMM, and to use them in project stupido II based on motronic from AAN engine.
I recommend you check SAAB's wiring diagrams, just to verify pin description, because there can be differences (I don't remember but it seems like peugeot, or opel uses same connector, but different pin assingmends). You don't like to plug burnoff to the singal output right ?
Sau
Yes i cheked the error codes and their wasnt anything related to amm.There is something wrong with the boost if you can read the thread "help" you will see what i mean,i bought the car with out amm so the only one i could get was from the opel,saab.
