Hi guys have a 93 s4 and today on the way home I went to accelerate and the car jolted massively! I mean it scared the sh*t out of me. Seems according to the boost display it happens between 1.4 and 1.5 bar and before hand it wouls sit at 2.0 comfortably. Its almost like hitting a rev limiter. Any ideas guys? Cheers
s4 jolts massively!
AAN boost leak testing
Agree. Most likely a split in the Michelin Man hose that opens up under full boost (but remains closed under lower boost levels)
AAN Boost Leak Testing Hints:
I had exactly the same symptoms your describing on my URS6 when i took a leap of faith and actually bought the car thinking i bet it's something simple.
Lift up the coil cover and look at the wires where they exit the back. Have they been chopped about in the past and is the original brown plastic sheathing on the wire heavily cracked causing arcing like mine was. There was absolutely nothing wrong with either my P.O.S. or my coils.I changed that part of the the loom for a good one and it has purred super smooth ever since achieving max 2.2 boost in 6th going up hill to give it as much aggravation/chance to play up as possible but perfect.
Give your wiring a try....a very probable cause along with what the other guys have said.
99 2.8 final edition CabrioletComment
This is the first time its happened and iv had the car a couple of months now. Will be another thing on my list to check. Need to try and get to the bottom intercooler hose anyone have any advice on how mainly without stripping unnecessary parts.Comment
Pressure test it instead of taking half the car apart
Remove the belly pan and the Michelin Man hose will be staring you in the face.RS2'd 93 UrS4 5 spd sedan
My idea with the wiring is only 3 allen bolts and it's of.Dead easy
I have had this 3 times and every time it was the MAF connector, pissed me off the first time as I was advised it was a boost leak and after spending hours pissing about looking for leaks and other stuff it was a simple 2 min fix. I would try the connector first as if it is that you will save hours of your time. If it isn't that you have lost nothing!
For ref
if not coil loom this could be problem as it sounds electrical to me.could even be the thermo switch
This is why the MAF connector is No.1 in the checks in my "One Missing and Hesitation Diagnostic" post:
This seems to be more of boost leak but time will tell.RS2'd 93 UrS4 5 spd sedan
