Urgent leaking fuel help please.
  • Human Joist
    • Nov 2012
    • 189
    Hi all. Recently bought an Audi S2 Avant aby that monkey magic just saved and I have had an issue today. Have been running round with a little fuel in the tank for the last few days and have noticed a fuel smell when driving occasionally when I out my foot down. Filled it up to top for the first time and came home parking it on the drive nose in on a slight downward slope. Noticed the fuel smell again and when looked underneath fuel is dripping off the bottom of the fuel tank quickly jacked it from the rear drivers side and it's stopped dripping.
    Help please where do I start looking for this one
  • irishs2
    • Apr 2009
    • 2455
    More than likely the fuel line has rusted . Most likely where it mounts to the body in the rubber clamps.
    Eric
    95 S2 Avant under rebuild.
    • Human Joist
      • Nov 2012
      • 189
      Ok will check there when little man asleep. All fuel lines looked to have been replaced. Maybe just not joined correctly. Seemed to be running down the side of the tank rather than from the line itself. But all help appreciated and will check it
      • irishs2
        • Apr 2009
        • 2455
        Oh maybe have a look at the access panel under the carpet in the rear. You can see where the lines feed into the tank. You might see evidence of whats going on there.
        Eric
        • Human Joist
          • Nov 2012
          • 189
          I can see the three fuel lines that run to the front of the car they appear to go in to the front most area of the tank. The leak would appear to running off the rear most portion of the tank.
          The access panel you refer to. Which side is it Eric. I take it I remove the rear sqabs then remove the rear of the carpet in the footwell, which side am I aiming for.
          Hopefully this will be a quick fix
          Jim
          • irishs2
            • Apr 2009
            • 2455
            You can see it bottom right in the pic in the load bay area.
            Eric
            • Christophski
              • 3632
              Just make sure you check all the ends of any rubber hosing to make sure it's not perished.....
              • Human Joist
                • Nov 2012
                • 189
                Right. Been hunting with beer paid assistance from monkey magic. Found this.
                Steve says it's called a bucket. But the plastic housing on top of the fuel pump has three cracks in it as can be seen in photo. The smell was coming from there and with engine running you can feel air being blown out. Covered it with some filling ptx instant gasket and the smell has gone. So I need one of these. Anyone know what they are called for the wanted section please.
                  • 4754
                  I thought that, as he had only just handed it over, he would come to the rescue. Still a few beers lubricates it nicely. Good car mates are hard to come by
                  • irishs2
                    • Apr 2009
                    • 2455
                    Audi still have them , best get a new one as the s/h one will be like this too if not then close to it. Another common failure point. I can get you a part number later
                    Eric
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      I think its what is refered to as a basket.
                      I only went round there to build his new bike and ended up under the car... ha ha...
                      • Human Joist
                        • Nov 2012
                        • 189
                        Cheers Steve. Eric, if you could get the part number that would be brill also the part number for the seal too just incase it's damaged
                        • irishs2
                          • Apr 2009
                          • 2455
                          8A0201319A should be around £45+vat
                          Eric
                          • kulster
                            • Sep 2007
                            • 290
                            Mines been changed too roughly about 8 months ago, bought it from tps. the rust from the pipe makes it crack, I'd smell fuel on full tank
                            • Human Joist
                              • Nov 2012
                              • 189
                              Cheers for help Eric. Nice to know mines not the only one kulster
