Hello guys.
I have a problem with my urs6 aan. Boost is 0.7 ( 1.7 on display) bar at 5000 rpm.
If I disconnect the hose to the wastegate have a 1.2( 2.2) bar. It's just a test, of course. Then the ECU cut gasoline pump. I have reviewed intercooler and hoses and I think I have no leaks. If I disconnect wires from the N75 valve, no change. Today I changed the one-way bleeder valve and the pressure regulating valve. Same thing. Disconnect MFTS and the same thing. I washed the MAF sensor with isopropyl alcohol. No fault codes. If I do diagnostics manually, then I hear the N75. If on the idle disconnect the N71, then ECU automatically disconnected N75is . I think that's normal.
Pop off is the new, of course. Spark plugs are new. What do I do, has anyone an idea?
thanks
thanks
