Hi Guys
My RS2 will not boost more than 0.9bars.
The car was running fine and we then changed the following:
Cam Belt and V Belts
Cam Timing (according to the Mechanic it seemed to be one tooth out)
New Dump Valve
New Samcos
New Plugs.
The car now has a very slight miss at about 2500rpm and then boosts to only 0.9bars. I also need to swing the engine a fewtimes before it starts.
Removed the WGFV and replaced it with a mechanical device and the car will hold 1.5bar boost or whatever I set the mechanical Valve to.
Gandalf cleared the faults but this one persists.
Cleared.
* VAG-COM Version: Release 311.2-N
Control Module Part Number: 8A0 907 551 C
Component and/or Version: 2,2l R5 MOTR.RHV RS2D01
Software Coding: PMC 4
Work Shop Code:
1 Fault Found:
00515 - Camshaft Position (Hall) Sensor (G40)
30-10 - Open or Short to B+ - Intermittent
- Cleared.
Work Shop Code:
2 Faults Found:
30-00 - Open or Short to B+
01-00 - Signal Shorted to B+
- Cleared.
Can any1 help.
Rgds
Shane
New Dump Valve
New Samcos
New Plugs.
Cleared.
Work Shop Code:
1 Fault Found:
- Cleared.
Work Shop Code:
2 Faults Found:
- Cleared.
Can any1 help.
Rgds
Shane
